Hi, I'm trying to install my 5906v viper into my deisel, I have figured out over 3days how to get the alarm system to lock an unlock the truck. Hood pin doesn't seem to work..I have grounded out the activation input, but when I arme the truck and open the hood from half shut position the pin makes contact but doesnt set truck off.
R/s doesnt work at all even with the ebrake wire splice connector. I ended up just removing the 10pin harness as I just cant figure out how to get it to work.
Does anyone have experience with the viper 5906v??
Kinda in a pinch and want the truck to be armed 100% with supplied products..if someone knows wire for wire, to help with safety connections an r/s wire connections, please help. Most online post dont have all the correct information.
I would bring it to someone but money is tight and I'm Mechanical inclined so I can figure it out, just need a helping hand.
I read there is suppose to be a pulse to the activation input but how to I achieve that at ground?
How do you tell the viper it's an automatic trans too?
