2003 F350 no turbo boost
3.4K views 19 replies 5 participants last post by  Hartwig
Good day,
I have a 2003 F350. EBP sensor shows KOEO 0psi . I have replaced the EBP sensor without improvement. MAP sensor shows 14,4psi, BARO 14.5psi.
Is it possible that the EBP sensor/wiring issue is causing a P0046?
Truck has no boost, no turbo codes.
#2 ·
It is possible. You’d be having some drivability issues too… surge, turbo lag. “No boost” is definitely a drivability issue lol. The connectors are prone to failure because of the location near the t-stat (heat). P0046 actually is a turbo-related code. This video might help you out (helped me once)
#18 ·
In which volt range is the actuator controlled by the PCM? I had thought about whether it would theoretically be possible to remove the actuator for testing and use a power supply unit to test whether the cam follower on the actuator moves?
Is the voltage from the PCM reversed? The actuator moves in 2 directions.
If you knew the voltage range in which the actuator is controlled, you could at least check whether it reacts.
I currently have no IDS. With Forscan, as far as I know, you cannot manually change VGTDC# to observe EBP_G (exhaust pressure) and MGP (manifold gauge pressure).
#19 ·
The ground side is pilulsed to ground the pct of cycling off and on is the pulse width. Example 10% on and 90% off would be a 10% pwm as an example. A 90% on would be 90% switched to ground and 10% off. This is a simple example of how pwm works. The scan tool usually has a control to let you manually position servos and other control devices. Look it up and see how your ST works in control mode.
