Ended up taking the truck to get something to eat, long story short I parked the truck and get out, and notice that coolant is just POURING out from under the front left side of the truck. So i popped the hood, and can very visibly see that the Degasse bottle (coolant overflow tank) had spewed out all over my battery and other accessories.
What would be the cause of losing all of this coolant?
Why is there such an immense pressure build up inside the tank that it literally pushes all of the coolant in the bottle out the top if I refill it?
Any help would be greatly appreciated. I built this motor and it has maaaybe 3-4,XXX miles on it and I got the motor as a long block so I never fooled with the heads so im not too worried about a headgasket crack or leak. There isn't any diesel inside the coolant tank or anything. The odd thing is that the truck isnt overheating. Well, ever since its happened I haven't ran it very hard and will continue to do so until my cooling system issue is fixed so I dont ruin all of the hard work put into getting it together. Just confused about why its shooting my coolant out, and i'm not able to find any information on the subject. No, i did not have the radiator cleaned before i put it in the truck so i'm thinking its possible i have a blockage somewhere in the cooling system.
