1995 F350 7.3l Dually RWD
2.1K views 4 replies 2 participants last post by  dandbon
Hey guys,
I just bought a 1995 F350 Dually manual. When I was driving it home, I had a catastrophic bearing failure on the driver's side rear. It snapped the axle and cracked the rear end housing right where the threads are for the spindle nut which holds in the bearings. The threads got bent out a little bit and I snapped a 1/2 breaker bar while trying to get the spindle nut off. The rest of the diff seems like it is in good condition so I wanted to try and fix it somehow. However, I may need a new rear end. Any pieces of advice or good spots to get one either online or around me? I live in central NJ.
#5 ·
Hey guys,
I have a 1995 F350 Dually 7.3 with a ?1988? f250 sterling 10.25 rear end and a 3.55 ratio. the tag on the diff cover says V126C for reference. I snapped the driver's side rear axle driving it home from buying it. Looks like the bearing had a catastrophic failure. The axle shaft has 35 splines on it and looks like its 36.75 inches long not including the flange at the end. I have been searching for a week for a replacement for it. I see a few on ebay but not the correct length because the ones available are for the C&C but I have a pickup. Does anyone know what I should do or have any leads on where to get one?
TLDR: Looking for a left rear axle shaft for a 1995 F350 dually approx 36.75 inches (not including the flange)
