Hello everyone. How many of you have replaced the front bearing assemblys on your 4wd trucks? Around how many miles did you get out of your oem ones and how many miles on the aftermarket ones you put on. Does any one know when they are recommended to be changed? Thankyou !
Many see 250k plus on the 99-03 7.3ls. there is only one serviceable part on them anyways. A small needle bearing on the back. you add some grease on it or simply tap it out and replace etc. if you have front abs riffraff diesel makes a special grease zerk adapter to use a grease gun vs removing the assembly.
you'll want to stay with Timken or oem or risk the consequences. Many powerstroke owners experimented with cheapies and suffered.
im at 151k and my friends exact same truck as mine is over 250k.
I plan on changing them at 225k regardless though.
