I have an 02 7.3L, and have a bit of a charging issue or draw. For the past few months it seems that if my truck sits for more than 24 hrs it won't start without a jump. If I plug the block heater in, it helps...but still has issues sometimes.
I had dual Yellow top Optimas and they are probably getting close to the end of their lives. I replaced the starting battery with a Blue top that I had in my Jeep and it seemed to be fine for a little while, and now its dead again. I tested the batteries as they sit, and right now the accessory battery is reading 13.45 volts, and the starting battery is giving me an odd reading; 18.xx right when I make contact with the terminals, then drops to 0.
If I get a jump, it fires up fine and I can drive it around all day and start it up, but the following day....dead. Are there common draws on the 7.3's to look out for? Any ideas or suggestions?
Thanks!
Thanks!
