its time for new shocks and the guy that had the truck before me put duel fron shocks up front. do i just get two new front shocks for it or do i get smaller once cuz there are two of them? its an 01 f350
sorry for the thread jack, but i was thinking of ordering a dual shock setup.. whats the differance between the hoop setup and the regular? would it be a softer ride if i added another shock? also i have 1 blistein 5100 now but could i add a blistien 7100 with the resi? or do i need to have 2 5100's or 2 7100's?
im sure you could run two different kinds of shocks but i wouldnt run two different shocks myself. different shocks=different performance etc. imo that is. im sure nothin bad would happen other than the shock with the most rebound would get more of a workout i suppose? im not sure abouth the dual shock hoops or having regular dual shock mounts but the hoops look nicer. thats all i can say about the hoops and that stuff. hope it helps lol
ya i know i dont need them but it came with them and i dont wont to change it all up. just didnt know if i had to get dif once cuz there are two of them or if i can just get two ment for the truck. just not sure how it works.
Valving is different between the shocks meant to be run single and those that are meant to be run dual. You DON'T want to run dual shocks that are valved to be installed as singles. Be sure you purchase specific shocks for what you want.
I think the reason for going with two is to combat heat build up when you are moving ALOT. I see no other reason. It looks silly. Yes two shock can fight each other. Two different valving styles for rebound and compression would act as one shock and have a completely different way of acting.
i am getting a compleat lift that comes with shocks i was just going to get 2 more of the shocks that come with it but i am guess i should look into it more so i get the right ones
Related Threads
Ford Powerstroke Diesel Forum
posts
5.5M
members
295K
Since
2005
