window regulator
1 reading
1.2K views 5 replies 5 participants last post by  greywarden
I have a 96 f-350 crew cab with power windows. I need a window regulator for the rear passanger side window. All the parts stores only have listings for the front window. Does anyone know if the front window regulator and the rear window regulator are the same? or if they are different where I might find one? None of the scrap yards in the area have any crew cabs for used parts.
Thanks, Chris
#4 ·
the front is different, I couldn't find regulator new anywhere, no one is making them! Local parts store Advance Auto found one for me in a junk yard in California in about 10 minutes, however was quite pricey. Good luck.
#5 ·
Mine in my CC quit working so I took it all apart thinking it needed a new motor,all it was is that the window sticks in the channel,a buddy of mine that works in a auto glass shop sprayed some lubricant in the channels and they work fine,he says he sees it all the time,windows sticking in the channels of older trucks.
