Status
Not open for further replies.
WICH 7.3L VALVE COVER GASKETS ARE BEST?
1 reading
16K views 5 replies 6 participants last post by  rvober6
I am having shut down issues and running on 6 cly with no throttle response. When dies it will start right up. I have thrown all the parts at it, IPR, ICP, EBP and checked the wiring harness for shorts. The harness over the valve looks ok.
So what do you guys think? FORD or after market? I would like to have your input.
2002 stock F-350 CC LWB 16O K
#6 ·
On my 2002 F250 7.3 the left bank went out. I did a lot of research and found that most of the people had the same problem. The wire harness inside the valve cover or outside was the problem. When I took off the valve cover on the left bank I saw the the plug of the inside wire harness slipped out half way. I pushed it back in, put a heat resistant cable tie around the plug to push up the lock and my truck was fixed. Obviously, the heat warpped the plasic plug lock so the plug could slip out. Easy fix.
Status
