I have an 08 F-250 with 89k miles...probably 20% of that with trailer towing time on it. Being that it's 12 years old almost, I was looking through the manual for when I need to change out the front diff, rear diff, and transfer case fluids. Manual says to change rear diff fluid at 50k, 100k, and 150k (for DANA axles only), front diff fluid at 150k, and transfer case fluid at 150k miles.
Couple questions. How do I know if I have a DANA axle? I don't think I do since the owners manual makes it sound like DANA axles are on the F-350's and above only...and that I have a 10.5" axle? So if I don't have a DANA axle, then when should I be changing the rear diff fluid, 150k like the other fluids?
I saw this in the Special Information maintenance section: "Rear axles and power take-off (PTO) units containing synthetic lubricant and light duty trucks equipped with Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service is required or the axle assembly has been submerged in water."
Are they really sealed for life units? I'm confused as crap! I attached the table of fluids I think I need from the manual.
Or should I just play it safe and change all 3 fluids at 90k or 100k miles since it tows occasionally? I haven't had any problems...maybe once every other month it will do a hard downshift when searching for the right gear.
