Well, last week, the wife and I took a trip to NE Oregon and on the way, I started feeling a vibration in my steering wheel and floorboard at freeway speeds. Truck is the one in my sig. Long story short, I jacked the front end off the ground yesterday to start "operation find the vibration" and i'm pretty sure my wheel bearings on both sides are bad. Driver side has a buzz/hum/drone when the wheel is spinning and the passenger side isn't as bad, but doesn't sound very happy either. I don't have any side to side play in either of them, but the sound is what bothers me. Plan is to R&R both sides next week as well as install new both front axle dust seal and knuckle/hub seals while i'm in there. Never done this before, but i'm pretty good at following directions (except if you ask my wife LOL). Between this site and youtube, I feel like i'm armed with enough info to try and tackle this. Wanted to run my list of parts past you guys to see if i'm missing anything as well as ask a few questions for you guys that have done this.
Parts list:
Timken wheel hub assembly with ABS sensor (x2)
OEM Knuckle seals (x2)
OEM axle dust seals (x2)
Anything else i'm missing?
I plan on renting the seal installer from O'Rileys for the axle dust and knuckle/hub seals. Other than that, it seems like i'll just need the basic hand tools, right? Also, any tips/tricks to getting the mounting studs out of the old assembly and into the new? That should be the only parts I need to transfer, correct? Am I safe in assuming that the oldmounting studs from the OEM part can be used with the new Timken part?
Any piece of info or insight that you guys can think of is appreciated!
Thanks.
-jokester
Parts list:
Thanks.
-jokester
