Status
Not open for further replies.
What is the "secondary" coolant system?
2 reading
23K views 12 replies 4 participants last post by  Roccafellas
I recently explored the beautiful and exciting world of coolant system maintenance. One term that came up during my forum-browsing on the subject is the "secondary" coolant system. I began reading the Ford document that someone linked to in a comment, but my eyes glazed over very quickly - the description sounded identical to the thing I would call the "primary" cooling system.
Will someone please dumb it down for me: what is the "secondary" system?
#2 ·
It’s a coolant system that cools the fuel and vgt actuator, there is an auxiliary pump on the drivers side behind the fan shroud.
You fill it by opening the black reservoir on the fuel cooler and also opening the 8mm inverted hex on the turbo and fill the black reservoir until coolant comes out of the vgt actuator side. You’re to do this while the the pump is running.. ie engine at operating temp
#3 ·
It’s a coolant system that cools the fuel and vgt actuator, there is an auxiliary pump on the drivers side behind the fan shroud. You fill it by opening the black reservoir on the fuel cooler and also opening the 8mm inverted hex on the turbo and fill the black reservoir until coolant comes out of the vgt actuator side. You’re to do this while the the pump is running.. ie engine at operating temp.
Thanks, Roccafellas. I'm familiar with the fuel cooler, but not the VGT actuator, or the Allen on the turbo - I'll have to look into that before I refill the system for real.
You may be the person to answer a more elaborate question on this subject. In the many pages of comments I read regarding a cooling system flush procedure, there was some debate regarding the interaction, if any, between that system and the primary system. Some people claimed they are connected, others claim they are separate. They appear to be separate, based on to the schematic I saw in a Ford manual (if my memory serves well, and it often doesn't). In my real-world investigation, they are clearly connected.
My question, then, is WTF? (Interpret/answer that however you see fit.) I just don't understand why they are considered separate systems.
#12 ·
I went back out to check and couldn't tell; ragweed and air quality are playing havoc on my sinus's right now. Whatever it is has the whole thing soaked from the bottom, and I couldn't see any sign of the leak at all from the top of the hood.
Degas bottle has coolant in it, isn't low and hasn't needed to be filled.
Of course my truck is stock right there, so it's a PITA to see that location from the top through all the hoses and see what it could be
Status
