I have a 2001 f350 cclb with the 7.3 and 6 speed transmission. It has 280k on it.
Recently it has started vibrating between 35 and 40 mph. It will do it in 3rd, 4th, and 5th (or in other words, every gear that allows for that speed range), as well as neutral. With the clutch in and transmission in any gear, the vibration goes away, but with the clutch in and the transmission in neutral, it will vibrate. Acceleration, deceleration, and engine load doesn't seem to make a difference. The vibration feels like mild rumble strip.
There is no noticeable play in the u joints or pinion bearing, and the only play in the mid span bearing seems to be due to the rubber bushing.
Any ideas which way to go from here?
