Hello all...
My lpop is definitely going out. With a pressure gauge hooked up, press fluctuates 30 down to 5 lbs (or less at full op temp) as the engine oil warms up. Inspection of the oil dropping out of the pressure regulator when removing its piston/spring, subtle amounts of very fine aluminum specks can be seen. Yes it's going bad and it's time.
Has anybody here seen or used the TamerX lpop repair kit? It comes with a special "spacer" that covers the gouging on the motor's front housing, and has its own gerotor gears with its billet cover, which eliminates the need to pull the harmonic balancer, replace housing cover, and associated gaskets/seals. TamerX claims a million mile or one year warranty.
The lpop repair kit can be seen here:
www.tamerx.com
Has anybody used this product and what were the results??
Ford Powerstroke 6.0L Oil Pump Repair 2003-2010: OEM TX-EOP60K ( Kit )
Tamerx Oil Pump Repair Kit TX-EOP60K for Ford Powerstroke 6.0L is built for 2003–2010 models. Premium quality, fast shipping, and in stock.
