Just set these codes today. Of course now my glow plugs are not working. Truck has H&S high sulfur tuning. Put i8n a call to H&S but they were 0 help. Told me to call ford. Anyway anyone else ever see these codes pop up and get it figured out?
@joemanhp4 - I had the exact problem you did. I live just north of Detroit and I deleted my truck (2013 F350), forgot to unplug the rear NOX sensor and CEL came on and changed out fuse 36 since it blew. About two years later (in winter), CEL came back on with the same codes you have, eventually went out on its own.
Well this past October/November when it started getting cold again here, it came back on with same code. I untaped every plug sprayed them all with contact cleaner and filled the plugs with dielectric grease and covered each one with the finger tips of rubber gloves and tapped them all back up. I physically removed both of my NoX sensors from my truck and put them in my toolbox. I deleted the code through my H&S Mini Maxx and I have not seen it come back on yet. I also cleaned all my battery terminals especially the battery that the wire from my tuner is connected too. I do not know if it was all coincidental, so far so good (fingers crossed).
Did you ever find a fix for this? I am having the same exact thing going on.2015 Deleted GDP tuned. U0074 consistent and sometimes accompanied by u0106. Unplugged emission BUS from PCM, same thing. Get code at start up or during warm up idle. Clear them and don't come back until next key cycle.
Anyone have the pinout or wiring diagram for the Glow Plug Control Module? Also thinking with the GPCM running the Urea Tank Heater something might be going on there.
