Transfer case 4WD solenoid
1 reading
8.1K views 6 replies 5 participants last post by  CH04stroker
Hello all, having some issues! I have a 2004 f-350 6.0 auto transmission, 4WD. While driving randomly I will get a lack in power and a change in noise from the truck. I pulled codes using forscan and I have a P1832- transmission transfer case 4WD solenoid circuit failure. I can only assume my symptoms, and that code are related, but while looking for a part number I drew a total blank. I couldn’t find anything..
So does anyone have a part number they know of? And I assume that solenoid is internal, am I correct?
#7 ·
the only way I can describe what I feel is like someone deployed parachutes attached to my truck for like 2-3 seconds and then it goes away. Only started yesterday, and that was the only new code I had on my truck so that’s what I figured. I really have no idea though, that was just my guess
#6 ·
Gonna replace that vacuum solenoid? Only use the Ford part, the others do not work properly
Reactions: bismic
