Just ordered a train horn for my 17. Has anybody used the factory horn to trigger the train horn? If you have where did you hook into? I plan on using an upfitter switch to be able to toggle between the regular horn and train.
How did your install go? I thought to use the same kit on my 2021, but Pete at Kleinn wrote me "It won't fit the 2021 F350 with the diesel intercooler, you will need the SDKIT17-734STL, the horns go in place of the spare tire on this one since they don't fit up front."This is the kit that I am using. Onboard Air and Train Horn System For 2017-2020 Ford F-250 / F-350 With Model 730 Demon Train Horn — Kleinn Air Horns
So what did you do with your spare tire? Carry it in the bed now?I ended up putting on this kit from hornblasters that uses the spare tire winch and raises up into its area.
