Status
Not open for further replies.
Tail light wiring
2 reading
48K views 7 replies 5 participants last post by  Left Coast Geek
I recently bought a 2000 F-250 Super Duty XL 7.3L diesel. The truck came with a flatbed when I bought it and I wanted to switch to a regular bed (better suited to my needs). I met with this guy on facebook marketplace to trade my flatbed for his 8ft 2002 F-250 bed, we got my flatbed off, got his bed on my truck, come to find out the flatbed used a totally different wiring setup than the original bed used and I couldn't hook up any of my tail lights. Looks like a trailer harness coming out the back of my truck, didn't have the same connection lead that the bed did, but I had to get home somehow because it was nighttime when we finished and I lived 50 miles away. We tried to cut and test each wire to see what it did but couldn't find anything live after the first couple minutes, turns out we blew a fuse. That's not the culprit for the inability to connect my truck to the bed's tail lights, but its yet another problem I have to deal with. What do the more experienced ford owners out there suggest I do? Money's tight and I can't afford a mechanic right now because of COVID so I'm trying to do it at home but if necessary I can reallocate some money around.
#2 · (Edited by Moderator)
Here are the rear lighting wire colors:
Lt grn / orn = Left turn and stop
Orn / lt blu = Right turn and stop
Brn = Tail, license, running
Blk/pnk = Back up
Black (slightly larger than the ones above) = Ground for rear lighting harness.
Lt grn = High mount brake light. Not used. May not be present in a later 2000 harness.
#3 ·
At the rear of the left frame, there should be two connectors coming out of the main harness that runs forward.
One has 6 fairly small gauge wires in it. This connector is for the bed lighting.
The other has 7 wires in it, 3 of them are large-ish gauge wires. This connector is for the 7-pin trailer tow connector.
Are there any connectors on the harness in the truck? Is the connector still on the bed wiring?
If = yes to either question, I would attempt to source a mating connector and splice it to the wires. Preferably, the bed wiring still has its connector, source a mating connector and splice it to the truck.
If all you have at the rear of the truck is a bunch of wires hanging out with no connectors:
Compare the colors in the bed harness to the truck harness. If you find the same wire in each harness, connect them together. You can use a flat-5 trailer wiring connector so you can remove the bed in the future without cutting wires. These should be available at a parts house. Splice the connector to both the truck and the bed harnesses.
Here are the bed lighting colors:
Blk/pnk = Back up
The rest of the wires at the rear of the truck are the Trailer Tow connector. I can help you with those also, if you need it.
Thanks, let me start by saying I really appreciate the help. I've been searching the internet for days for wiring diagrams and what not but this is the most helpful thing yet.
There are no connectors coming out of my bed, just the two sets of wires for their respective uses but each tied off. But, I do have the connector on the bed, so should I look into getting a matching connector for the tail light wires on my truck, connect them to their respective colors, and I should be good, right?
#6 ·
i have a complete 2002 wiring diagram book, freekin 600 pages or something
that shows connectors:
1) C422 - right side
-- pin 1 black/pink - reverse lights
-- pin 2 black - ground
-- pin 3 brown - license and park light
-- pin 4 orange/lt blue - right turn / brake / hazard
2) C432 - left side
-- pin 1 - black/pink - reverse
-- pin 2 - black - ground
-- pin 3 - brown - license and park
-- pin 4 - lt green / orange - left turn / brake / hazard
reverse lamps are on a separate connector C487 (left), C488 (right).
grrr, this gets complicated. looks like there's different harnesses for the different versions. connector C408 is common to both SRW and no-bed and I suspect is up near the cab, but just has the left/right turn/brake/hazard lamp on it..
of course, these connectors aren't shown in the connector diagrams, nor is their location indicated anywhere I stumbled on.
Save
#7 ·
I just bought an F350 with a F250 swapped bed. All the lights were working besides my taillights. It was VERY frustrating. It turned out the taillight wire corroded so much it just disintegrated in one part near the hitch. The Haynes manual provided very good schematic diagrams without being overly detailed. I can confirm the above colors, but you will probably want to get a Hayne's manual so you can confirm your year and so forth (and they're just a handy reference). Good luck!!
#8 ·
oh, that C422/C423 was specifically for 'no bed' trucks (flatbeds, utility, etc). pickup bed trucks have a different harness from C408 to C????, that was where I was going when I started to lose track of all the connectors, spread across 8 different pages in a 600 page book.
Save
Status
