SYNC Voice commands Not working Help?
9.3K views 6 replies 5 participants last post by  KR2012f250
I have s 2015 F250. 60K miles. Iv had it just over a year. A Few days ago I hit the voice commands button on the steering wheel and got a visual "redial" last number called on the screen. I cleared it and tried again. Driving I just waited but can not get it to go to any other option. I went thru the book..I did what was recomended...no fix. Did a Master Reset today and I unlinked my phone. I still had the same problem. Reconnected my phone and still same issue.
Any ideas?? Could it be in the button on steering wheel? Or is it the SYNC system?
#6 ·
I posted before, but can not find my original post. The Voice Comands on my SYNC system stopped working a couple months ago. I did all the online options for a non mechanic. Pulled fuse, reset etc. . . Finally got an apt at FORD and had a diagnostic.
They are saying my AIPM is bad? $1200 to replace. I really want it fixed but the more I read, the more I am curious. My radio works, my phone connects, the bluetooth and navigation all seem fine. CDs play and calls come thru and go out. Only issue is voice commands.
No one seemed to have much info in my prior post.
Any experience with this?
I also have a warning light (also checked at the dealership) for the heater on my exhaust system, so I have to take it back to have that replaced (its under the warranty).
My only reason for question is because on the estimate, it says "radio problems". I don't have a radio problem. . . so any help?
#7 ·
I just went through a similar issue on my 2012. One of my batteries died on startup, at the same time, the NAV system was booting up, I believe the low voltage caused the sync files to get corrupted. I tried the master reset (would not complete the reset), pulled the fuse on the NAV system (did not fix it, still would not dial out using voice commands). Went to syncmyride.com, entered my vin# and downloaded the availabile file and did the software update per instructions. This rewrote the corrupted file. System/voice command for phone working again.
