Yes, there was a code but I can't remember the exact number and eventually it will go into reduce power mode due to the shavings clogging the filter. You should see metal flakes in the fuel filter bowl
My situation is this: The truck sat for about 2 months. When I came home it fired right up and shut off liike 2 seconds later. Batteries went dead trying to restart it. Charged batteries. truck would turn over but not start. Batteries died after a few attempts. Took batteries to station to get a better charge. Truck turns over and sounds strong but still will not crank. No codes. No messages. I am hoping the batteries are just too weak to start but am scared it may be a fuel pump issue?
Mu uncle came over and load tested the batteries for me, they seem fine. He could also hear the fuel pump turn on when i put the key in th eon position so hopefully that isnt the issue.
Also after trying to crank a hand full of times and doing the ke on key off thing a couple of times I noticed the dash lights dimming the last time i tried to crank. Could it be a battery issue after all?
I know after changing fuel filters I usually cycle the fuel pump a good number of times to try and prime everything back up (I even pre-fill the oil filter from my 7.3 habits) and it cranks about .5 seconds longer than normal operation.
Does your scan tool have any datalog streaming? May be worth while to check some pressures to see if it's getting what it needs when cranking.
Also, newer vehicles hate sitting. I left mine sit for about a month and both batteries were dead (brought them back from 4V lol) and have been fine since. If I don't drive it at least once a week I'll let the remote start run for 15 minutes to keep her up and fresh. My 7.3 sits for much longer (and is a manual so not remoting it) but has some big Optima deep cycle batteries in place and those things are beasts (started at -30F, never plug it in, to see if it was not gelled or would warm up, gelled and died 30 seconds later, 6.7 was gelled and would not supply enough fuel past idle), they are way to tall for the 6.7 though
Have you figured out what the issue is ? I have same problem with my truck and same code came up
This post has been deleted
Status
Not open for further replies.
Related Threads
Ford Powerstroke Diesel Forum
posts
5.5M
members
294K
Since
2005
