Hey Guys !!!
Long time member (but more like a weekend novice).
Its taken me 20+ years (online here) to learn the little I do know, and I have tackled some complicated tasks...
thanks again !!! LOL
Original owner of '01 F250 PSD 7.3 that developed bad GEM. NO windshield leaks, just a bad solder joint it seems. Anyways .... I FINALLY found exact same model GEM on E-Bay. Bought and swapped it out and all my issues were resolved, I thought. \
My truck is 2 wheel drive (and even my original GEM attached ) had 4X4 marked on it so I assumed the replacement was cross-compatible.
A recent Forscan ( also attached) indicated many DTC's associated with 4X4 transmission.
FYI, the ( DTC B1352 is something I did, disconnected ignition chime from key cylinder)
My question is...
Can I modify the GEM via Forscan Lite to progarm that the config on my truck is two wheel drive and not 4 wheel drive ??? I do not have any other trans issues, that I'm aware of.... or that are reflected in KOEO or KOER scans.
I seem to be having trouble uploading the .pdf of the scan so will need to post .jpeg's
Thanks for ALL YOUR HELP over the years.
Mikey G
My question is...
Mikey G
