I don’t have my stockers anymore but I am going back to stock to run PMF 3 link arms.
Since you don't have the stockers, then you are really just guessing right???
So here's what's going to happen. You go to an alignment shop, they install 0* cams. They do a check to see what cams need to be installed. Those cams will be your "stock" cams. Then you install the arms. I don't see a real requirement but you might want to check the alignment again just to be sure.
There is NO WAY to determine what you need by VIN, part number, or whatever. The stock cams are from the factory, set by the requirements there, and shipped to the lot. SPC lists multiple cams that will fit with no issues. You
might get away with another truck that is the same cab/bed configuration as a good estimate. In the end.....you will need an alignment to know 1000% for sure.
Which is why I gave the idea of just installing the arms, do the alignment and see what happens. There's 10,000 ways to skin this cat.....but they all evolve the use of an alignment machine to see what cam to install.
