Was hoping to get some help here onto different thing I can look into.
Speedometer on my 1997 F-250 HD 4-wheel drive was giving me problems the past two weeks by jumping all over the place, and that in turn would make the transmission not knowing which gear it's in .No it got so bad that I can not even drive it till I find out what's going wrong. This is what I believe is an electrical problem, (I am thinking if a broken wire) since the speedometer is all over the place . It will go to the far right side of the speedometer (85mph) or the far left side(0mph) and just stay on my last road trip. I used to wander all over the place which at that time I thought it was a slight opening or crack in the wire, because this issue would come up with the speedometer while I was driving in wet road conditions and if the conditions were dry the truck would go back to normal but that's not the case anymore.
This is what I have tried so far:
New ABS sensor
Check and replaced any brake light that were out including the third brake light.
Changed the computer box that is located on the firewall from a 1996 truck. I thought this was the answer since right afterwards the truck started working perfectly again with no issues.
The ABS light is on, but I can only think its a ground issue, since the cruise works.
So, Has anybody gone though this? I seen other issues of this on the forum, but not this bad.
Has anybody know of a website that I go that shows which wires to follow from the ABS to track down to see if there is a break?
There is no code being thrown, if that helps.
I had wiring problems before with it going in and out of OD, but looking at some post and my replies from the group here help me correct that.
With the problem that I had with the OD and still driving it, did I burn something out before It finally started to work in OD?
If there is a ground problem for the light of the ABS to be on would this cause my problem with the cruise still working?
What is the box mounted to the frame rail underneath the driver seat called that the ABS wires run to? And also how do you check if this box is working correctly?
I don't want to be taking items off the truck and replacing/ wasting time if someone might know where I should start.
Since most of the websites say this is a speedometer to ABS problem, that's what I am looking at, but could it be a soleind problem in the transmission?
Thanks to all that reply.
New ABS sensor
