Severe motor oil leak - Any ideas?
1 reading
6.9K views 9 replies 2 participants last post by  Gord from Emsdale
I finally got my 08/6.4 running real nice, no odd noises, just running like it should, I got out of the truck, went around the front, saw a bunch of oil on the ground, I then shut it off & crawled underneath to take a look, It looks like it is leaking motor oil from the back of the engine up by the Turbo.
I check with the scan tool, no codes, temps, normal, no engine light.
Any idea what is leaking?
Thanks..
..Gord
#3 ·
Ok, thanks, it is not the dipstick tube, the leak is from up high, I guess I'll have to lift the cab a bit & pull the turbos. I was kind of hoping not to do that, I just finished putting it back together. I know it is not the oil line on the top of the turbo, I just put on a new one. It is a really hard job to do this time of year, its cold out here, usually -6 to -10, snows a lot & just miserable to work in. I have another 6.4 truck in the basement of my shop & I can't move it, so I'm stuck working out side.
Thanks for the help.
#5 ·
Thanks, I will do that, its a pretty bad leak, it will pump out a quart in 20-30 minutes. I just put all new cab mounts on so they will be easy to undo and lift it a couple inches. The guy I bought it from is a real moron, when he lifted the cab to do some work, the torched off all the cab bolts, cut the EM brake cable just after it comes out of the cab, he also cut all the ground wires broke the shifter cable, all the bolts he had removed were left in a bucket outside, so they got real rusty sitting in a bucket of water. it was just a night mare to put back together & Now that I'm almost done, I really didn't need this extra leak.
Thank you for the help & Have a good day.
#7 ·
I bought all new body mounts, he torched the old bolts & the body mounts were pretty well shot anyway.
I started tearing it down this afternoon, I lifted the cab 5 inches, lots of room now I just have the up pipe bolts to remove & then pull the turbos. I took the heat shield off and it is looking pretty dry under there. Along the right side of the intake manifold is fairly wet under it, the drivers side is dry as a bone. Could the oil cooler leak like that?
#8 ·
Update, I took the turbo off this afternoon, didn't need to remove the fuel or oil caps. Even with lifting the cab a bit, those up pipe bolts are a pain for sure. When I lifted the turbo I saw cause of the oil leak, I guess the previous owner wasn't careful enough when he put the turbo on. The turbo drain fitting was damaged & with a fitting like that, its not much wonder it was just pumping the oil out like crazy.
Thanks to everyone for their help.
#9 ·
This should be your part number. Should be 9T514. It’s a complete kit. Should come with new up pipe gaskets, that orange drain tube, new up pipe bolts and crush washers for the oil feed lines. I would order another 9T516B. The kit does come with a replacement O-Ring for the drain tube on the low pressure turbo but they bend super easy. Around $150 for both from local dealer
