Finally got around to deleting my truck today and when I finally finished and went to load a tune I get this device comm error. Anyone else had this problem?
Just had this error. Sct told me $100 to fix. So I happened to stumble upon this post. I did exactly what you said and - no more error! It does say unable to read truck info but there was an update that is currently being downloaded to it. Hopefully this works and saves me $100 and a week without my truck.I dunno, but here's what worked for me..
Take the 4 screws out of the back..
Carefully pry apart the two halves. There's a screen ribbon connector with a slide in clip in connector thingy. Disconnect the screen. The slide clip is easy to put back in place and so is the ribbon connector. You'll see..
Flip the unit over.
Replace the CR2032 battery with a new one.
Pry up the tape over the SD card holder.
Slide the holder toward the top of the unit and it'll pop up & open.
Take out the SD card and make sure all the connectors are clean & pretty
Put it all back together..
Plug it in..
Send me a Thanks if it works. Saved me $100 and "7-10 Business days..."
