Replacing Cab Mount Bushings: DIY or Pro?
2 reading
20K views 17 replies 11 participants last post by  GregWork
Hello all again. Stock 2016 F350 6.7. I am new and have already received some great help on a couple other problems I am having. This one concerns the 8 cab mount bushings. The ones that came stock are rotted and at least 2 are almost completely gone. I am looking for advice on changing them out. Is that a job I can do with my limited skills in my driveway or do they need to be done by a professional? Also what brand of bushings do you recommend? I have attached a pic of one of them. I am hearing more noise now when I am on a rough road and believe its the bushings. Thanks in advance for any advice on this issue. Quite honestly I am perplexed as to why the bushings are worn out. I have read that the bushings are made from substandard material but don't know enough about it to say one way or the other. Is this a problem with Fords or do other brands have this issue. Anyway. Thanks.
#2 ·
Lots of threads on this exact topic - search the community and you'll get the answers you need.
To cut to the point, this can be DIY in your driveway, as many have done (including myself), but you have to be careful, use the right tools, and take the advice that's been given on the forum.
As far as product, most people (including myself) would recommend S&B body mounts. Again, do some research on the forum and decide for yourself.
#8 ·
Think about some things that have happened over the automotive industry. The desire to stop using plastics or other type materials, moving to a tad more "earth" friendly products. So let's make stuff with plant based/soy based materials....hence it's a great product, it works, it works well, it just has a short life.
Not to mention...ask yourself why animals/squirrels are eating away at wiring harnesses.....yep....plant based wiring coverings.
Just $.02.....
#7 ·
Do not try this at home. It can be done… but why? This is what I did.
I called Ford North America and complained about all of mine cracking and rotting out. Apparently this is a huge issue for them so they had a dealership replace all of mine for $340.00. You may pay less since your truck is newer. And you’ll get the new style cab mounts. Just call Ford!!!
#12 ·
They’re not that bad to change, I own a shop and didn’t have an open lift when I did mine, did them in the lot. My induction heater worked well for getting the bolts loose without fuss, they’re essential tool in rusty areas!
#13 ·
I wanted induction, but map gas is much cheaper.
You need muscles and patience. Don’t use an impact or you will be tearing out the interior to fix the cage nuts…
Sawzall may be needed if they’re rusted together.
#16 ·
Definitely S&B!!
And go out every day leading up to the job and spray lots of penetrating oil on the bolts. You will be glad you did!!
As stated, DO NOT use any sort of impact wrench!! It’s tedious with a ratchet and socket, but much less than fixing the cage nuts.
Mark
#17 ·
I did the bushings in the driveway yesterday. Relatively easy with the exception of one bolt which I cannot remove. I found a work around, but my recommendation for anyone doing this project is to torch the bolts before removal. I know, everyone recommends this. What I learned was to reheat them as you go. Get them hot, start backing out. If cranking them gets harder, REHEAT! I hope this helps someone.
