remote starter questions (12 volt solutions)
2.8K views 26 replies 4 participants last post by  Danielenglish92
New here,
I have a 16 F-350 SRW PSD lariat value package and I want to add a remote starter to it. Did a little reading and ordered the one from 12 volt solutions. Just looking to get some install info, time, difficulty ect.
TIA!
#7 · (Edited)
Why do aftermarket? I bought the key, antenna, and wire for around 150$ if I remember right. Fairway ford parts was selling them online. Then go into forscan and enable it in the bcm.
I had the key cut at autozone and programmed in forscan even though you can program it easily at the column.
Took me a couple minutes to pull the headliner down a bit over the driver seat and plug in the antenna.
#10 · (Edited)
Here is the install document. Ignore the glovebox part. The antenna is above drivers seat in 15-16, glovebox for 11-14. Almost all trucks already have hood switch, except XL models. You can easily check yours.
FairwayFordParts.net
Phone: 330-533-3673 ext 1438
Email: shipping@fairwayfordparts.com
Website: Fairway Ford Parts | OEM Ford Parts and Accessories
Here is a link to just the antenna part for $30, then need just 1 key and forscan. Done.
#20 ·
Wat he’d the instructional videos on their site and he says only the one isn’t you don’t have automatic lights which I have and the other is for the long range remotes which I didn’t get so I put a call in to support. I’ll see Monday. I’ll update here.
