I have a 2006 6.0 with what looks to be a Rear Main Seal leak. According to dealer, Bed Plate leaks are more common and leak where the rear main leak would show up. I have read postings here and talked to dealer about this and dealer says that leaking rear main seals in 6.0 are rare. He says they will have to take a look to determine whether it is rear main seal, bed plate gasket, or a hose in the area. If it is a bed plate gasket, then it's off with the cab and out with the motor to repair. Does all this sound right to anyone? Has anyone experienced what they thought was a rear main seal and after it was replaced the leaks kept leaking? Both are covered under warranty and truck has only 51k miles.
