I removed the rear diff cover yesterday evening to let it drain overnight. The cover had many inside gouges, dents and two small holes that someone had previously sealed with rtv sealant instead if buying a new cover. Apparently, a gear or two exploded sometime in the past before I bought the truck.
I didn't think to see if I could remove the fill plug before removing the cover. This morning I crawled back under the truck to remove fill plug. Not budging. Took some P.B. Blaster to it and my small O.A. torch to give it some heat. Pulling hard on the breaker bar with a 3/8" extension, she began to move. Or, so I thought. Inside of plug rounded the extension and perhaps the inside of the plug.
I thought the inside of the plug was simply a square - 3/8" ratchet fitting.
Did the previous "mechanic" use something else or does it take a special tool like a wierd torx bit ?
Had the same problem with the 5 speed transmission drain & fill plugs. They ain't coming out.
More heat ? Special removal tool ?
I've never had trouble removing any fill & drain plugs until this truck... Any alternatives to filling diff ?
I'm considering doing a live stream event as I blow this truck to smithereens... just kidding, but it would relieve the frustration and be fun to watch !
Thx for any ideas... Truck is ready to go down the road once I refill the diff...
