04 6.0 -
want to remove the radiator and clean real good before replacing my oil cooler.
I know I have drain coolant, pull lower hose, pull upper hose and degas hose. unbolt the shroud up top, pull back the wiring harness up top. Disconnect the two tranny lines.
Any tricks, on the tranny lines? do I need to remove the fan and shroud? Do I pull up and out? or do I pull down?
thanks guys,
thanks guys,
