P160A
1 reading
18K views 2 replies 2 participants last post by  JBakerd517
Engine check light came on. This code came up.
Code: P160A - Control Module Vehicle Options Reconfiguration Error
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame :
-LOAD: 43.14 % - Calculated Load Value
-ECT2_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1_SUP: No - Engine Coolant Temperature Sensor 1 supported
-ECT1: 215 °C - Engine Coolant Temperature Sensor 1
-ECT2: 215 °C - Engine Coolant Temperature Sensor 2
Any guesses to what is causing this?
#3 ·
Status:
  • DTC Present at Time of Request
  • Malfunction Indicator Lamp is Off for this DTC
Freeze Frame :
was you getting reduced engine power with this? i am but no other check engine lights.
