I have a 2016 6.7. F250. I’m new to diesels Why don’t these trucks come with a oil pressure gauge ? Is it not important to monitor on a diesel?
Less than 50 psi? I am in no way an expert on the 6.7, but if ford has designed an engine that does not exceed 50 psi of oil pressure even at cold idle, then I need to figure out how I'm going to unload mine. My 6.0 could easily hit 80 psi cold and ran ~60 psi hot at speed at 200k miles. I'd expect no less of the 6.7.
As to the specs posted above, if the PCM is monitoring those values, is it available to be monitored through normal options? I'm new to the 6.7, but not to Ford. I know previous engines only had a switch that threw a light or dropped the gauge if the pressure dropped below about 7 psi. Is this different on the 6.7? I've looked for a PID on my NDash, but haven't ran across one that I thought was it. They are not necessarily named for easy recognition on the NDash. If it's not monitored by the PCM, how can you expect it to shut down the engine when the pressure is dropping to levels below those specified. Sure, it could kill the engine when the switch finally fell below 7 psi, but as stated, it's usually too late then.
I'm not arguing. These are serious questions.
I prefer to know I have a sufficient supply pressure rather than depend on the PCM to determine it.
