I have a 2002 Ford F-250 4x4 7.3 Powerstroke. I have done so much work to this truck that it might as well be brand new. This truck started as a project. Now, it’s a headache!
Right now, I am dealing with rough idle/no power and a mystery leak that just blows my damn mind!
The leak is a consistent dribble. After about 1 minute, the puddles are about the size of the palm of a medium sized hand. Yes…TWO puddles! One puddle directly under the transmission/flywheel inspection cover and another puddle directly under the starter area.
Before you tell me “it could be your turbo/turbo pedestal/o-rings”, or “it might be your high pressure oil line(s), or “it could be your rear cover (above rear main seal)” or “it could be your rear main seal”….ect, here is a list of what I’ve done so far:
-Dropped transmission to change rear main seal and pulled rear cover off and re-sealed it
-Brand New oil pan, oil pan gasket and oil dipstick/tube
-Brand New oil cooler, oil cooler o-rings and oil cooler gaskets
-BRAND NEW KC300X turbo AND turbo pedestal, AND new o-rings (all four!)
-Brand new steel braided CNC Fab HPOP lines with HPX
-Brand New stage 2 CNC Fab HPOP (replaced last week)
-Brand New stage 1.5 180cc 30% injectors with PHP hydra tuner
-Brand New Ford Motorcraft IPR (replaced last week)
-Brand New IDM
-Brand New PCM
-Brand New wiring harness
-2 BRAND NEW batteries (replaced last week)
-Brand new fuel filter (for the fuel bowl)
-Fresh Shell Rotella 15-40 oil and is topped off with a fresh oil filter.
All that work and it STILL idles rough and is gutless and…you guessed it…it STILL leaks as well!
Notice one part I didn’t mention replacing…
—> ICP
I’ve recently unplugged it and noticed oil inside of the ICP connector. I know faulty ICP’s can cause rough idle and loss of power/limited power, so I will need to replace it and find out if it solves that issue.
I have heard of people experiencing leaking a large amount of oil from their ICP (due to worn out o-ring) and the oil traveling down through that hole in the back of the valley dripping from the same places (that are mentioned above) as the oil dripping from my truck.
I have yet to notice any oil seeping around my ICP, and if it is leaking and I somehow can’t see the leak, it is definitely not leaking a noticeable amount. So, I’m baffled!
Before you ask, yes I have already checked both plugs on the back of the gallery. They are DRY!
What about crank walk? With everything I have done so far, I’m now starting to wonder about crank walk! Are these engines known for crank walk? Is crank walk common with these engines? Would crank walk cause an oil leak? I have watched my harmonic balancer and my flywheel (with transmission dropped) and both seem sturdy and not wobbly at all and moving evenly and balanced, which would lead me to believe that if my engine had any crank walk, it would be so small it’s unnoticeable.
Im mostly focused on the oil leak issue.
I don’t have a scanner and can’t check codes, therefore I can have my local diesel shop do that part.
Any help brainstorming and figuring out where my mystery oil leak is coming from is greatly appreciated, not just by me but also by others who are experiencing the same issues.
(99-03 7.3L Powerstroke)
What are ALL possible reasons why oil would leak from the rear of the engine, causing oil to puddle up on the ground directly under the starter as well as directly under the transmission/flywheel inspection cover?
Two puddles, both the size of a palm of a medium-sized hand within 1 minute’s time after the truck warms up.
Those who graciously offer their time and expertise helping to solve this issue are greatly appreciated! You are not just helping me, but anyone who has the same leak issue and are struggling to find answers regarding the issue.
-Brand New IDM
-Brand New PCM
—> ICP
