Oil anti drain back
25K views 8 replies 5 participants last post by  lah2420
Looking into why my truck all of a sudden is taking 4 to 8 seconds to crank. Doing the easy checks first. ICP jumps to 585 right after starting to crank. One thing I read was the anti drain back valve could cause this. How do you check it? I changed oil and pressed down on the top of the stem, poured a little oil in the housing, and watched it drain. Don't know if that is a valid test or not.
#2 ·
What is your IPR when you have the long crank?
-jokester
#4 ·
Yes, I know. I only use Motorcraft. My question is how to test to see if the valve is working. With the filter out, can you just push down on the part that goes into the filter and close it? I did that and the oil I poured in still drained.
#5 ·
No - the part that the filter slides on to is just a pipe with a bypass valve in it. This is in case your oil filter clogs, the oil will bypass the filter and still be able to flow (somewhat). What you need to press down to test is inside the bottom of the housing, to the rear right of the oil filter pipe. You'll see a little black button with a spring on the bottom of it (might not see the spring due to the remaining oil). Like postmaster said, when your filter is in and cap is screwed down all the way, this spring is compressed, sealing the valve, keeping oil inside the housing.
-jokester
Reactions: lah2420
#7 · (Edited)
Jokester, in answer to your first question. The IPR reading on my ScanGauge is 14.8 koeo and goes to 50.1 in less than a second when I start to crank. Then it goes to 84.7 after a couple of seconds. I think the Scangauge is delayed about a second in displaying readings.
#8 ·
one method is when you pull the cap and filter ( after letting the truck sit for a while) the filter should be dripping with oil
thats why it is best to avoid a mess to let the filter sit in the housing for a while after you open it up and let it drain out through the valve
if the filter is already dryish when you pop the filter up then you likely have a valve issue
