I understand your frustration, so many 6.0 owners have gone through so many of the same issues. "Fix one thing and two more things pop up." And just when you finally get it working and are confident you fixed all the weak points the truck proves you wrong. It makes it difficult to remain loyal to Ford. I suppose its not all Fords fault for using what I will call, "the most unreliable diesel engine in Fords history." After all International built it. Sure they were under more stringent requirements to build more fuel efficient, less polluting engines. I say shame on International for giving this engine the "stamp of approval" and sending it out the door. Every truck owner is "proud of their truck" and it shows, because they buy the best parts and keep it in top shape. But where is the pride that Ford/International have in there product?
An engine mounted FICM that vibrates so much it breaks the solder welds at the capacitors?
A Engine wiring harness that becomes brittle in under 10 years and fails?
An EGR cooler that was so poorly designed that its inevitable failure will blow you head gaskets?
A Fuel injection system in a "work truck" that needs to be so clean that it will cause injector failure?
TTY Head bolts, and only 4 to a cylinder, on an engine that has an 18:1 compression ratio?
An oil cooler with such close clearances that it fails causing the EGR cooler to overheat and fail?
These are just a few of the most common problems every 6.0 owner has come across. And this was there "best design".
And I still paid $56,000 for the truck..............Bummer. Hindsight is I suppose 20/20
Good Luck Sixpackstillers and try to keep your cool, as I will most likely bet you'll run into another challenge or two in the future. Remember Your not the only one who is "sick of working on it". And I'll bet that when its running good nothing can beat it, and you'll forget if only for a moment all the problems it gave you.
