Hey y'all - so I'm a bit frustrated, just got done with a ball joint and front end job and was replacing all the pads and rotors. Driver's side rear caliper had a seized piston in it.
Went to NAPA for a reman and they sold me the driver's rear caliper. I get home and as I'm connecting it up I realize the bleeder nipple is below the line connection. Great, they gave me the wrong one. A common enough occurrence. I've even read of guys buying two rears and they installed them both upside down and can't bleed them. They also said I should have plastic pistons and I have metal on both sides. So I requested a metal one again.
This is where is gets strange - I go to NAPA today and they tell me it's the same thing on each side. Their computer tells them it's the same part number. They pull all the stock they have in the store and every one would place the bleeder nipple on the bottom on the driver's side. What the heck?? Even the plastic piston ones are like that. I walk next door to the Ford dealer and the parts person says 'there are definitely two different ones, one for each side'.
I call another NAPA - they pull their stock and guess what?! All the wrong ones again.
Ok, am I missing something? What's up with this?
Other important question - is it important to have both metal or both plastic piston rear calipers or can I have one of each if I find the right one?
Thanks in advance guys.
Scott
Scott
