My First Manual Regen
37K views 13 replies 8 participants last post by  jrghac
I'm getting ready for a 250 mile tow trip and wanted to measure fuel mileage, but went out to dinner tonight and %DPF Full was at 80% so I wanted that regen out of the way. About a mile or so before returning home, DPF went to full and a regen started. The wife didn't feel like a joy ride and I remembered the manual regen. As soon as I pulled up at home, I hit the CTS menu and found manual regen under either Maintenance or Diagnostics and selected it. I had to respond to at least 10 prompts about the heat and not parking in a wheat field, open the hood, be in Park or Neutral with the parking brake on, etc. Suddenly the screen changed to a set of gauges with DPF Load, Soot GPL, ECT Temp, EGT1 temp and the engine went to 2000 RPM where it stayed for the next 25 minutes. Then either the cooling fans and/or turbo kicked in and it sounded like I was standing next to a 747 revving for take off. The heat was amazing as the ambient was 72, parked in the shade with a 10-20 breeze, but it got to almost 92 in the cab. As GPL got to about .70 the loud noise stopped but it continued to idle at 2000 RPM and then EGT1 started backing down from the 645 degrees it had been. Finally, it dropped to normal idle speed and a count down of 20 seconds began on the CTS. When it was done, it returned to my normal gauge screen. My fuel level (also on the regen screen) had dropped from 74% to 69%.
While I normally prefer to drive through the regen, that wasn't convenient and this was given that the regen had already began (GPL had dropped from 3.50 to 3.10) and this was a good way to complete it before my trip. Also, %DPF Full dropped to 15%, the lowest I had seen it and soot GPL dropped to .65, also the lowest I had seen so the process is pretty effective.
Reactions: HeavyAssault
#2 ·
My CTS also revs to 2k rpm and engages the fan clutch 100% during the length of the parked regen. I've noticed that when you do a parked regen with a snapon OBDII tool the fan clutch sometimes doesn't engage.
Not really sure why you didn't just let it regen during the tow trip, not going to hurt anything unless you just wanted to play with it, but thank you for your insight for the rest of the readers.
#3 ·
I plan to test my DP-Tuner Heavy Tow tune with the same trip that I tested the Light Tow tune with and didn't want a regen interfering. Ordinarily, I would just let the regen complete with the next drive. Last time, I headed out with the Light Tow and returned with the Heavy Tow and am doing the reverse this trip.
#4 ·
Gotcha, and makes sense now that I've followed up on your post in my DP Tuner thread.
Let's see the numberssss..........
I'd always play it safe with the 35 horse over 50 when doing that 10k trailer even though it isnt an extreme amount of weight, I know advanced timing under a full load over time doesn't play real nice.
But then again, Jody tunes fairly conservatively.
Aw hell its a damn crapshoot.
#5 ·
i didn't know there was a way to see what % your DPF was at on these trucks…where do you go to see that?
#6 ·
You can have it added to your gauges (top menu selection on the dash) by your dealer or do it yourself with FORScan. Many dealers don't know the process but it is to turn on Forced Regeneration in the settings.
This is how to get to the %DPF screen for "Exhaust filter".
(1) IDS "talking" with truck via VCM
(2) Toolbox selected to get to the Module Programming
(3) Programmable Parameters for our trucks
(4) Select Personality Parameter to program
(5) Change "Forced Regeneration Request" to Enabled.
(6) Programming complete and VCM can be disconnected from truck
Ghost Screen now appears
#7 ·
With FORScan go to:
-"IPC as-built"
-scroll to 720-01-01
- there are three boxes, the first one don't modify
- second box insert "9" in the first of the four places to turn on DPF % (put a "1" to remove the DFP %)
- in the third box put a capital "E" in the first place to set "Force Regen" to "off"
..........................................."F" to set to "Force Regen" "on" but "Compass" will turn "off"
..........................................."6" to turn off "Force Regen" but "Compass" on
.......................................or "7" to turn "on" both at the same time
-save and exit
-cycle key
Done
#8 ·
I just installed a used (30k miles) DPF on my 2012 truck. The diesel specialist was kind enough to do a flash upgrade to my computer, and it added the manual def option. As this was a used DPF (got it for 400 bucks, plus 200 to install minus 200 recycling.)I wanted to start with a clean filter. Started at 90%load, took about 15 minutes and used .6 gallons of gas. Love it. down to 0% on the meter and -12% load on my FORScan (iOS).
My DPF was cracked and not catching all the soot, so I decided to change it before it got worst and dropped a code.
Anyone know if it does any harm to do a Manual rather than wait to drive it? It's a daily driver, so not always able to finish a Regen on the road.
#9 ·
Manual regen is what the dealer does when you take it in for DPF issues so it doesn't hurt it. It is more cost effective to let it do it while driving as some of the driving heats the exhaust.
Did you mean .6 gal? That is the usual amount.
#12 ·
I have a 2012. I never had the screen either. When the shop installed my used dpf a couple days ago, the tech was kind enough (No extra charge, and it wasn't a stealer) to install the latest module flash. It automatically activated the Operator commanded regen. I had to scroll right on the gauge menu, and it showed the dpf load. Once it reached 85%, it automatically gave me the option to manually clean it. Pretty cool, and a great option if you don't have a chance to drive to regen. I feel that .6 gallons is very reasonable.
#13 ·
I have the 3rd screen activated on my 14 and can see the filter % and watch it decrease as it is in regen. However, mine does it when it gets full.
Does anyone know why my 14 doesn't have a manual regen?
Tom
#14 ·
The only time the manual regen option will show up is after the load gets to over 85%. I didn't think mine had it either after they upgraded the module because it only showed the percentage. Once it hit 85%, it showed a "Press ok to clean" button. Also, you may have to have it in park and the emergency brake on.
