Status
Not open for further replies.
21 - 40 of 55 Posts
Here's a great shot of the rear of the engine. You can see both up pipes as well as the pipe that fed the lower (horizontal) EGR cooler. If you remove that pipe, then the block off plate moves up to that junction which comes off the passenger side up pipe. Which is just to the right of the yellow dot labeled #2.
Save
Thanks Mike. Glad the same block off plate will work for either end of the egr pipe. I do believe I saw somewhere that the drivers side up pipe can be pulled without removing the trans and the passenger cant because of the downpipe. Hopefully someone can chime in that has done it in cab before.
Save
Thanks. Ill hack the egr pipe out, tap the blocker plate, rotate the line, fandangle the uppipe out, and get the service bolt for the top manifold stud.
Save
I have an 08 6.4
I don't see that pipe yall are talking about moving the block off plate to.
egr delete
dpf delete
Spartan tuner
afe cai
aftermarket up pipes
ebp sensor eliminator (meant for 6.0 I later found out)
I get up to 58 psi when I hammer it. before I even get to 3/4 throttle the truck just stops performing and doesn't have any power.
its throwing p006b code and p2263 code
any ideas????
I realize now that the up pipes don't come with the place to bolt the egr piping onto the passenger side pipe. so the mod in this thread won't work for me.
any other recommendations?
b-adams... how in the heck did you get your hands back on the top piece to get the bolts out... holy crap that's tight. im in the middle of doing this right now and I already don't like it!
This is the outcome of reaching back to get the bolts out. I managed to get the front bolt out but the back one was stuck big. I used a 12" fine saws all blade and carefully cut between the flanges to cut the rear bolt.
Save
I did the probe mount pretty much the same as B.Adams other than installing a longer brass fitting to the block off plate thinking it would make it easier to hook the compression fitting to the plate. I also didn't need to extend the wires due to a shorter run to fit the probe up.
Save
You can remove the driver side pipe if you cut it apart! BUT!!! What I did was remove my inner fender well and cut the pipe right above the bellow with a Milwaukee cordless saws all (much smaller to get in there) and the top 6 inches fell out. This was all after I struggled to get the flange apart, that was a real fun job! I ended up sawing the back bolt to get her apart. THEN, I left the dummy pipe in there. It's still connected to the bracket and tight:dunno: I didn't see any reason to take it out! I was just about out of fresh type A transfusion blood up to that point:look:
So what I'm suggesting is save some time, blood, and frustration. Make 1 cut above the bellows, remove the 4 bolts holding the top section of the pipe and remove it leaving the rest of the pipe in place. Only thing left then is to relocate the sensor. You would need to purchase a seperate block off plate.
One other thing I WISH I had done was used a galvanised pipe for an extension instead of brass. Not sure the brass won't crack with vibration???
Save
I think your in for a tranny drop or a cab off if your doing the passenger side. This thread is pretty much all about eliminating the driver side pipe and relocating the probe.
Save
I'm wondering if anyone noticed more exhaust noise after deleting the driver side regen pipe? Don't know why it would but mine seems louder. Maybe it's just because I've been running my 5.4 Super Duty gasser and juming back into the Diesel is messing with me???
Save
Figured I'd continue in here, instead of starting another thread......
In the middle of "relocating" the EBP to clean up the up-pipe coming off the EGR......can a bung just be welded on the main up-pipe and sensor screwed in or does it need the tube as well??? thanks!
I'd think that may be too much heat for the sensor. The tube puts the sensor farther away from the exhaust.
Thats my first thought, but is just a guess.
Put the sensor in your block off plate with the tube and all. Keep it from freezing up too
Save
Why wouldn't you put it on the block off plate like I did on page 28? You need the block off up there anyway, just put the bung up there!
NOTE: Don't use brass like I did in the photo. It's to soft and it will not last. I put black pipe in it's place and just came off about a 6000 mile run and it held up fin. I used a 6 inch length of pipe so I wouldn't need to extend the wires.
Save
Too much heat on the sensor that way.
I don't think there is any more heat in that area than being attached to the engine:dunno: but what ever??? I'm not the only guy that's done it this way.
Save
Too much heat to not use the tube, area doesn't matter. Too much heat for the sensor to be placed directly in the pipe and not use the tube.
Well.......y'all were right about the heat :nod:.......
Got another EBP sensor ordered, just need to find a male to male for the bung......:look::look::look:.......so I can use the tube and relocate it way from the heat
21 - 40 of 55 Posts
Status
