I've been wanting to install a mechanical low oil pressure gauge on my 95, f350 so I don't have to rely on the idiot gauge that came stock with this truck. I bought a Max Tow to match the other gauges I've already installed but this is where I run into a problem. There's no way to connect into the stock sensor/switch. Has anyone installed a mechanical gauge on this year of a 7.3 and if so what brand of gauge and could you post video of the install?
Also, could these numbers I have be verified by 7.3 mechanic
7.3L Power Stroke oil pressure
Idle 10 PSI
3,300 RPM 40-70 PSI Thank You
Idle 10 PSI
