Ive recently acquired a 99 f250 7.3 with 6 speed manual transmission. Has 250k miles. No idea when clutch was last changed or what type is in it. Only mods to the truck are a 6 position clip which has a broken switch, and muffler has been cut off so its straight piped.
When I got the truck it was fine. No issues but after driving it more it grinds. I did have a fuel leak when I first drove it home (fuel filter lid was loose) and it leaked all under the truck.
So I always start in second gear. So 3,4,5 and sometimes 6 grind when shifting into them. It does it way worse once all the way warmed up (30 mins or so of driving). Reverse gets hard to shift into as well. Downshifting seems fine. There is a bad noise when taking off at low speed but that's the only times it does it. I'm guessing syncros are bad with the grinding but I'm not so sure since all of them gears grind and it all of a sudden started grinding.
I've checked hydro fluid and its full. I tried removing tranny fill plug but its stuck so I'm assuming it hasn't been changed in awhile.
Any ideas what could be causing the grinding all of a sudden? Clutch feels fine but gotta have pedal close to the floor. I read that's common.
