Hi, I have a 2011 F-550 flatbed wrecker with the 6.7 diesel. It is throwing codes p0093 and p228e. everytime it suddenly stalls while driving. It will stall about 3 times within a mile of driving at 45 mph. I can drop it in nuetral, turn the keys off then on and will crank right up. On the scanner I see the frame pump shutting off when it dies. Using freeze frame, there is no evidence of loss of pressure when the stall occurs.
A new high pressure and low pressure pump have been installed as well as the fuel pressure regulator and fuel pressure sensor. Nothing has changed the condition.
Does anyone have any thoughts about what's going on?
I am convinced that the PCM is shutting the motor down.
I ran it down the road with the pressure sensor unplugged and though it was in limited power mode, it never stalled in ten miles.
