Location Defrost Mode Door Actuator
1 reading
9.6K views 1 reply 1 participant last post by  hardhatz
I have the opposite problem as everybody else.
NO defrost.
Vacuum is fine.
Temp controls nicely.
I suspect the Defrost Mode Door is stuck.
Where is the actuator located?
Man I have beat my brains out online, and I seem to be the only person who ever had this problem.....
Thx!
#2 ·
Solved.
Super Duty (2007) Defrost vacuum actuator is located below the rear of the radio.
Remove the instrument face panel and radio. It is 8 inches below, and will be covered by fiberglass insulation. Follow the vacuum hose.
2 screws.
The spring inside mine failed. Therefore no default defrost.
The part was $28 on Amazon.
Motorcraft YH1490 control valve assembly.
