I requested a quote on this engine as I am doing research since I may be in need of a replacement engine soon. I was told $12,500. I also got a build sheet. I will try to paste it here but not sure if it will work since I am on my phone:
“The J&K PowerstrokeR”
Designed and built by J&K Engines
DESCRIPTION: We bored and stroked a 6.0 liter Power Stroke to a 6.3 liter making it 383 cu.in. More displacement resulted in dramatic gains in horsepower and torque! The entire rotating assembly has been Blue Printed and Balanced and Dyno tested with results. We stroked our 2004 F-250 utility truck with no upgrades, just simply a stock configuration.
RESULTS: stock 6.0 f-250
270 HP @ 3300 rpm (at the wheels)
485 ft lbs of torque @ 2000 rpm (at the wheels)
RESULTS: 6.3 “ Powerstroke’R”
446 HP @ 3125 rpm (at the wheels)
850 ft lb of torque @ 2670 rpm (at the wheels)
The “6.3 Powerstroke’R” gained
176 horses and 365 ft. lbs of torque!
These dramatic power gains are based on
NO modifications to the
stock 2004 F-250. With a 2.5 inch exhaust. Any mods that anyone does to this platform will increase the HP and torque even more.
COMPONENTS AND PROCESS:
• 6.0 liter block bored .040
• Oil galley plugs tapped and screwed in.
• 2010 6.4 Power Stroke crankshaft custom machined and balanced.
• Connecting rods, honed and balanced.
• .040 Mahle pistons, milled, notched and balanced. Pistons tops are ceramic coated and skirts are also coated by PolyDyn, check them out,
Performance coatings by Polydyn.
• G-rotor, for low pressure oil pump is custom machined.
• Front engine cover is custom machined to fit 2010 6.4 Power Stroke crank shaft.
• G-rotor cover custom machined.
• Harmonic balancer is machined and balanced.
• Flex plate balanced.
• Mains, rod and cam bearings are coated by PolyDyn, for longer life and less wear,
• Rear engine timing cover with rear main oil seal.
• Custom Teflon to Teflon aircraft grade front main oil seal.
• SCT X4 power flash programmer with a custom tune installed for the 6.3 displacement.
Remember this stroker process is on a 2004 Ford F-250 all stock! Now, if our stroker is installed in a
2005/2007 F series with the newer FICM, you would gain an additional 55 horses and torque would increase as well. Also the 05/07’s have a 3 inch exhaust which adds even more power.
