interior cab and exterior cab lights will not shut off
1 reading
21K views 12 replies 7 participants last post by  Patrick Feeley
Any one have ideas or solutions for why the 3rd High mount light and dome light will not shut off?
#2 ·
Is it the little wheel that controls the dimming and brightening of all in cab lights? On my trucks that wheel will turn the lights all on including the truck bed light.
#5 ·
The system 'thinks' the door is open
#9 ·
Try turning the Main Light Switch fully in the clockwise direction. Rotating the switch in either direction will dim/brighten the dash lights and the click at the end of travel in the counterclockwise direction will turn on the cargo light and dome light (door open or closed). If that's not it, it could be the switch itself. Cheers!
owns 1997 Ford F250 XLT SC 4x4 LB
#13 ·
Try testing the main light switch per the attached. Also check the button switches in the door jambs for making/breaking continuity. Cheers!
Reactions: Hydro
