No I am fine with giving some info if you are actually looking to help the situation but I am not looking to get into a discussion over what the actual fault of the failures is which is quickly what this is turning into. I have been down this road for two years and tired of hearing you had to do something wrong or its your problem. I've had a very reputable shop working on my truck and I know what I am talking about or I just keep my mouth shut. 4 engines in that time is very much just the engine, pistons to be exact. I kept the last two blocks that cracked pistons and they show that no injector is stuck, nothing is melted, and everything is normal, just cracked. I maintain my trucks as they should be by the book and with all OEM Ford parts, including brake pads and batteries so no maintenance is not the issue.
The first failure happened at 102,000 just out of warranty. A long block was installed by a Ford dealer full of idiots in Oklahoma. It was claimed to be a stuck injector. I should mention the fact that they wanted to reuse all but one injector in the new long block, I refused and paid for all 8 to be replaced since they blamed the issue on that. I went above and beyond at every breakdown to be sure everything was replaced and done right. Then 30 days later at about 105,000 it failed again in the same manor this time in Vegas. Again to a Ford dealer who put the blame on the previous dealer for not changing the fuel pump. I never saw any parts of the truck on either of these failures but the both had the same symptoms.
The third failure came with a $20,000 bill and a compete engine with another complete warranty. That is a complete drop in replacement, new pump, injectors, everything. 5 months and about 15,000 miles later if fails again. I tow it 800 miles home to a dealer where I can take my time and be there daily to be sure it gets fixed right. At this point I still know nothing of the piston issues of the 6.4. The dealer promises to work with me to be sure the truck is warrantied and get it fixed correctly. They don't they refuse warranty and claim it to be a stuck injector due to bad fuel. I loose my cool and promptly tow it to a private owned diesel shop. Upon finishing the tear down it was found that a piston was simply cracked in half. No injectors stuck, nothing melted. It still had oil all over the piston and cylinder walls, and still had carbon on top of the pistons. Everything was fine just cracked in half, except for the fact that the idiots at the dealer left my fuel pump torn open so it corroded and bent the hell out of the compressor wheels on my turbo. We rebuilt the engine with the same injectors, had to use a new fuel pump, and did some other things. Deleted it, studded it, ceramic coated the pistons, and tuned the truck down some.
It ran for a year and about 20,000 miles and did the exact same thing again. This time when we called for warranty on the short block that was purchased from Ford they said that unless it spun a crank bearing they will not warranty a 6.4 short block. Another words we know the pistons are garbage so we just keep blowing those claims off. They use the fuel card as a way to put it on the customer. In my case I see these issues way faster and more often than most because my truck is an F450 box truck that runs around at about 80% of its max capacity at all times. you would never see it this often in a pick up.
This is a serious thing, Ford is ripping people off, and the two blocks I have are proof of it. What I need is expert opinions that know this is a huge well known issue, and will speak on it. I am also looking for customers of Ford with pictures, and bills that show these issues so I can prove it is a very prevalent issue. I want to go to court with at least 24 documented cases of this happening so I can show a jury that this is a prevalent thing that Ford is ignoring, and even installing more engines and parts with the same problems that come with a warranty they already know they will not honor. I have lost a lot more than money in this battle, I have almost lost my business, a chance at buying a home, and a few employees. You can call me an idiot for fixing the truck over and over but when your that far in, and a Ford dealer keeps giving you a warranty and claiming it is fixed right you keep telling yourself it has to be right this time. I have obviously now discovered the International Max Force pistons, which even more tell the tale that Ford is ripping people off and covering up the trash they are selling. A cab and chassis should of had those pistons from day one. The truck is rated as something like a 26,000 lb GCVWR. The worst part is I have owned nothing but Fords my whole life and ALWAYS serviced them at a dealer or myself with ALL ford parts. I was a die hard, I am that ******* that loves his 6.0 and will take it to the grave, I have 5 fords right now, and every time I get in one of them I want to vomit now.
