So for the last 10+ years I have been pumping out the hpop reservoiron my 01 7.3 during oil changes . I was reading that after pumping there is still dirty oil left in the rails . This may be proven out by the fact that after I do the first pump out ,refill it, run it for a minute or so then pump it out again ,the oil is dirty . So usually I repeat this minimum of 2 or 3 times till I get clean oil ( or cleaner oil) even after 4 times it is still a bit dirty . So here are my questions for you experts :
1. Where does the oil in the hpop reservoir get replenished from ? Does the oil in the rails return to the reservoir or to the crankcase?
2. I seem to remember that once during an oil change that the hpop res. drained by itself ... I could be dreaming here since I am old and forgetful. Is this possible?
3. My sequence has been drain crankcase , change oil and filter ,then pump the hpop res. and change it several times . I don't mind wasting the oil ...I want maximum life out of my injectors . Is there a better way ?
Thank you very much for any tips .
