For those with a gravity feed auxiliary tank:
1. When fueling do you fill the factory tank first and then the auxiliary tank? I'm guessing the small hose connecting the two won't allow enough flow to just fill both through the auxiliary tank?
2. I would want an in line filter between the tanks. What type/brand works in this type of application?
3. Any reason gravity feed isn't a good idea? I'm going to install an RDS the fits underneath my existing tool box. Cost is the main reason I'm looking at gravity feed.
Thanks guys.
Thanks guys.
