Frustration
I have been having a problem that I THINK I have tracked back to those nylon tubes. I have a 48 gallon steel replacement tank that make the fit even tighter. My truck would start up fine and run great for about 5 miles and then would feel like it was starving for fuel until it would not accelerate at all. I had done the hutch mod years ago so no in tank filters to plug but dropped the tank and there was obvious sediment and crap on the bottom. Took it to a good radiator shop and had it flushed, reinstalled, not better?!?
Drove it to a local DSL shop who said the #8 injector was failing... They have about 170K on them so decided to replace with FFD Stage 1.5, Edge for basic data and code reading, FRX, HPx. Starts up great, runs fine for about 5 miles... Changed the fuel filter and upon shining a bright lite inside, found a ton of MUDDY SLUDGE :surprise: Bought the fuel bowl seal kit and reinstalled, no change. Bought fuel pressure tester and am getting 60psi, UNTIL IT IS UNDER LOAD where it drops to 0 !!! Pulled line to pump and installed tubing into a jug of fuel and it runs great with no pressure drop at all. The issue has to be from the tank to the pump! Dropped tank AGAIN, blew out lines really well this time, took apart and checked all connections and reinstalled. No change!!?! Replaced nylon tubing with new fuel line using OE "quick connects" and reinstalled. NO Change! The tubing is making a hell of an s curve and it may be getting crushed, VERY TIGHT FIT that cannot be seen or felt. Did the exterior jug intake again to confirm and it still does run great when not pulling from the main tank. The angle of the sender fitting is about 7 o'clock and the feed and return lines about 3 o'clock. A 90 degree elbow on 1 end might help but I hate the idea of restricting the line.
Suggestions?
