Just finished installing an Edge EAS to monitor Fuel Pressure and Coolant Pressure on my 2005 Ford F250 6.0. It's got 220k on the clock. I bought the 100psi pressure sensors here https://www.amazon.com/dp/B00NIK9E10?psc=1 for the install. Everything went fine but now that the sensors are installed I find I either have a bad fuel pump or I have something wrong in the Edge MyStyle where I set the parameters for the sensors.
The fuel pressure reads a max pressure of 22psi. At WOT it dropped to almost 15psi. The truck runs fine, no stumbling or other signs that the injectors are starving for fuel. I know that doesn't necessarily matter until the low fuel pressure ruins an injector. The sensors in the link above spec this:
Pressure Range: 0-100 psi
Material :Stainless steel
Output: 0.5V – 4.5V linear voltage output. 0 psi outputs 0.5V, 50 psi outputs 2.5V, 100 psi outputs 4.5V
Working Temperature: -40—+125ºC;.
I watched a YouTube by cr38er and he used similar sensors for his Edge EAS setup. He said that .5 volts was 0 psi and 4.5 volts was 100 psi, so that's what I used for the parameters in the MyStyle program when set up my Insight CTS2 Monitor from my laptop.
So, what do ya'll think have I got an error for the values in my Monitor Setup for the sensors. Or is the reading I'm getting of 22 psi max at idle and under normal acceleration true? Will these trucks even run with fuel pressure that low?
Just for information, I used the same parameters for the sensor monitoring coolant pressure. On a half hour drive unloaded averaging 75mph the highest pressure I saw was 11.5psi. I think that's correct and working properly.
Thanks for any help,
TXPower
TXPower
