Front wheel hub / seal / knuckle questions
1 reading
12K views 28 replies 6 participants last post by  ZMANN
My passenger side wheel was getting uneven wear and I jacked it up and found the hub was bad. I got a replacement and disassembled to find a couple other issues. My Ford Workshop manual which is famous for incorrect torque values seems to completely skip over this particular axle, only showing info for "Full floating axle - dana". I think mine's a dana 60 but not sure. It's a "normal" front axle for a 2004 F350 4x4 SRW truck, but I'm having a hard time finding info on it.
Besides the hub itself, the problem seems to be with the seal just-pumpkin-side of the wheel bearing. Perhaps called the vacuum seal. On disassembly it seemed to separate in a way it probably isn't supposed to (not sure if they are supposed to separate) and it has what looks like a crack in a rubber part.
Note my truck does not have automatic locking hubs - no vacuum lines. I suspect it uses all the same parts at the wheel though.
Can someone confirm that seal needs replacement and throw me a part number?
Question 2 is about grease fittings. I don't see how to grease the top ball joint on the knuckle. All other places have a fitting that is obvious. For the top, I'm wondering if this broken fitting shown here is supposed to provide the grease for the top ball joint. It's pretty far away from it but maybe a passage inside transports the grease? It could also be a vacuum line and if so, I'd hate to put a grease fitting on it and crank it full of grease. Is this a grease fitting and if not, where is the grease fitting for the upper ball joint?
Thanks!
#2 ·
The "grease fitting" you have there is actually the place where the Vacuum line is attached if you had 4wd.
Some ball joints are sealed. I know that on mine they are not and they are filled from the bottom. I have a 4WD truck so there is a 90 degree grease fitting that is between the bottom of the ball joint and the axle.
If you don't have that fitting then I bet yours are non-greasable.
As far as your other question is concerned.. I don't know. I have a 4WD truck.
Sent from my Pixel 3 XL using Tapatalk
#3 ·
Thanks on the fitting info - makes sense. All have an obvious fitting except that top one so I thought it was odd. I'll recheck but you're probably right and it's a sealed fitting
Mine's a 4WD ;)
#5 ·
Yep. Though I think Ford uses the vacuum parts at the wheels just to keep it simple. I have no 4x4 dial or button inside. Just shift the diff and if the hubs aren't already locked, manually lock them.
#6 ·
The ball joint without the fitting is probably still the OE one. Why in gods name someone would change some of the joints is baffling. Although as I typed that, maybe their store only had another brand in stock for that position, so it was used.
It's been a long time since I had been into the front knuckles, but I believe it's not uncommon for those to blow apart on removal.
owns 2003 Ford F-350 Lariet
#7 ·
It would probably be best for me to first ID the axle but I'm unsure where to get the data to do that. Here's some hot pix of it:
Though only the passenger side hub was the issue, thought I'd look at the inside of the drivers side hub and lo and behold there's a rubber/plastic ring hanging loose there as well. (see quick video
And I'm not sure how that "front outer or inner or vacuum" seal comes off. If you look at this quick video
it seems it must come off at the wheel side since it can't get past the yoke of the u-joint. I'd rather get an idea of how it comes off before I start experimenting
I definately won't be disassembling any more than I need to here so unless something goes very wrong, the knuckles are staying where they are. I just have to solve the mystery of the "seal"
#8 ·
dana 60 but you are at the cutoff
in 05 they changed some things when they went to coil called a Dana super 60 ( not to be confused with the widetrac )
so you have a dust seal on the axle shaft between the knuckle and axle C ( hula hoop seal , called this because it is always loose) and flipping around )the axle
and you have a unitized seal ( spins inside itself ) ( yours has seperated inside the knuckle on the hub side
you will need a driver to install that seal this is a vacuum seal but for you it will be just a dirt and water seal
this has more seals than your after but this is the type of kit u want
#9 ·
Reason 4389 to buy a 05 or newer if you want a 6.0 ....
@ZMANN thanks! yeah my "guess" was going to be the Dana 60. On the surface it appears so because of the year (2004), springs (leaf), and stub shaft splines (30 @ hub end) that it's likely to be a Dana 60. I'd love some way to be sure. Everything I've found is pretty non-official like this repost of some info someone found here:
Yes, 2004's changed mid year on a number of things (eg: my engine is an '03 and I have leaf springs). Not sure how to tell if it has "king pin style knuckles" or gear size (without pulling the cover).
Then again, I'm not 100% sure if "stub shaft splines" above refers to the end that goes to the tire or the end that sticks into the diff. Because the tire side is 30 (Dana 60) and the diff end is 35 (Dana Super 60). I found only one "good" image of an oem cover for these and it was for the super 60 and it looks exactly like my cover. Unable to find a cover pic for a plain Dana 60.
The kit you indicated looks like the deal but while I know where the large vacuum seal and the small o-ring go, I don't know where the two smaller seals go - is it possible mine have been missing? Images below.
And to pile on, upon pulling out the axle I find crap on it. I think it just picked up the crap from the (dirty) hole on it's way out - inside the axle hole you see tons of crap in there and drag-marks indicating the theory it was picked up on the way out. Does that need to be cleaned? And I'm not sure how I'll be able to re-insert it without taking some grit along for the ride - hard to be so steady as to hold it completely level for the whole trip.
Here's some pics of the dirty hole and the shaft...
I keep digging deeper and am answering none of my own questions along the way - only adding more unfortunately. I'm inclined to settle for "Dana 60" at this point because of your info, the spline count, year, and the leaf springs.
#10 ·
And if anyone has an exploded diagram of the axle end showing seal location, etc, that'd be damn skippy if you'd be willing to post it. Again - not in the dang service manual that I can find.
#11 ·
And I see reference to "reverse rotation high pinion front" and just "reverse rotation" - I have no idea what this means but some parts mention it, others don't.
#17 ·
This place is a good resource for parts and info.
Early Ford Bronco and Truck Restoration Parts - Jeff's Bronco Graveyard is another place for parts.
I've used Jeff's long ago (had a '78 Bronco I should have never sold) and makes sense they'd be a good resource (plus they are not far from me). That Video by venturestruckparts was awesome. Thanks!
your knuckle seal part # is in your own image
So it is! I was able to look it up. I'm not used to the numbers on Ford parts actually being part numbers you can look up.
Also I took your advice and went to parts.ford - no info on the site so I called. Person gave me the wrong part (probably my fault for explaining it wrong). But I think I have enough info to go forward without them. WRT the dealership - they piss me off beyond belief whenever I go there so I avoid them like the plague. However, if I'm in the mood to be treated like a POS and pay 2x for the same part you can get from ford.parts, they are my go-to people. Even thinking about it is bringing up my blood pressure...
any suggestions for cleaning out that tube w/o opening the diff cover? Or should I not even bother and just be careful on reinstall of the axle?
#18 ·
FordPartsGiant.com is a better place to look up parts, although not a Ford dealer, so I often buy elsewhere if the warranty is a concern - or pricing.
Cleaning out the Ford Superduty front axle tubes - An endeavor for the free thinker. There have been so many ways of how people have done this. But, of course, when rinsing or wet cleaning, always have the axle drooped, so stuff flows downhill and out the tube, not into the pumpkin.
775234
775235
I don't think this fits.
775236
#20 ·
LOL some interesting methods there. I'll probably go with something like that half-circle scraper - looks good enough. That and work hard to attempt @ZMANN 's suggestion to keep it steady. I might employ a younger person at that moment. Mine does not have the plastic fitting - that'd be nice.
Parts I ordered was a kit venturestruckparts made up of the 2 spicer seals (inner/dust seal and outer/vacuum seal).
Here are the ford part numbers for future readers:
Inner / dust seal >> F81Z1S175HCA
Outer / vacuum seal >> F81Z-3254-CB
O-Ring seal on hub >> f81z-4a322-aa (I did not need/order one of these, as I have one on my new hub)
One confusing thing about these parts is that in many places you'll see they are for the Dana 50 but I believe the reality is that the Dana 50 and Dana 60 use these same parts.
Fitting these seals on without buying the $50 tool will be my next hurdle. I may have to make a tool. Or if anyone has any tricks for that please advise.
Thanks,
#21 ·
That would be my choice of tool, too.
In the day, when I did mine the tool could be fabbed from a pipe nipple and flange with some grinding. I'll see if I can find a reference.
#22 ·
#24 ·
as far as the diy tool i have made them for both the 04 and 05 up
and they do not work as well as the proper tool I own the proper tools now that set the depth
the 04 seems to be an easier DIY tool with the 1 1/4 pipe
and with no vacuum leaks to be worried about you should be able to make the DIY version and be fine
#25 ·
Do you over think everything like this [emoji16]?
As you've figured out, you have a dana 60 axle with 35 spline shafts, the 30 spline is the hub spline count, not axle spline. The cover for the D60 is the same as the cover for the Super 60. If you ever need to replace the cover, use an 08 cover.
You have the seal kit. Jump on Amazon and order the proper tool for seating the outer seal, I think I paid $80 for my 06 seal driver, but yours will be a different model #, make sure you're buying the driver for an 03/04 axle. The big seal goes on the stub (wheel side) shaft. The little seal sits in the axle tube. It should be driven into (onto?) the axle housing before putting the axle in. It will help support the axle shaft as you slide it down the tube, but still try to keep the splines out of any goo in the tube.
I would recommend replacing the u-joints on the axles while it is out.
#26 ·
I've spent 20 minutes thinking on this question and while I could spend much more time on it and go into lots of detail, I've decided to just answer "yes" :)
Yeah, I figured I'd have to wait on the part anyway and after an hour or two of thought decided to break down and purchase the tool. I think I got mine for $60 at amazon. I think I need to do an entire cabinet for "special" tools.
That would be the smart thing to do, but for now I'm going to leave 'em. It's hard to know where to draw the line, but next time I go in there it's going to be a breeze. This job did not go at all like replacing a $35 hub on my old Buick LeSabre. I was pretty thrown off when I realized my Ford manual didn't show any info on this axle. Pretty t-o'd about the manual.
Hopefully my manic "process" that I repeatedly display in writing here on PowerStroke.org isn't going to get me thrown off the site :) I'm not sure what I'd do without all this help and info. Well - I guess I do - torch the truck and buy another '05 LeSabre while I think out my next steps.
